When I bought my bike, the PO had switched back to the stock tank from the Clarke that he bought. I ran out of gas shortly after I started driving it. There was no low fuel light! Turns out when he plugged the fuel pump harness to the tank he bent one of the pins.
I straightened it out but made sure to fill up every 45 miles or less to be safe.
FF to today. After unsuccessfully putting the Clarke tank back on, I have to go back to the stocker. Figuring it was a good time to check the light with no fuel in the tank, I plugged everything in and...nothing. No low fuel light. All the pins are straight.
I know what color the wire is from looking in the manual, but how can I test this? check resistance in fluid and out? Bad sensor? bad light?
I want to go riding with a friend (he's got DR) but I have such pitiful fuel range I want to play it safe.
