The manual is a bit "vague" as to the vendors part numbers for the bearings and seals. Our local dealer collapsed so we are in a bit of a tight spot in SA right now, so herewith the part numbers for the bearings (I used SKF products)
Parts Manual reference SKF Number
Item 9 (small seal) 25x42x7 CC
Item 44 (big seal) 32x42x7 PU
Item 8 (small bearing) 60042RSR (2 Required)
Item 59 (big bearing) 60052RSR
Hope this helps anyone in a fix.
