G gasser250sm New member Jan 8, 2009 #1 Ive sourced a 07/08/09 GG OEM pipe but i have a 02 ec 250, wil it fir with minor adjustments? or major ones? thanks
GMP Active member Jan 8, 2009 #2 It will fit with some tweaking, its a good performing pipe IMO. Paul (PEB) put one on an '01, perhaps he can give you some details.
P PEB New member Jan 8, 2009 #3 I put an 06 pipe on my 02 nearly bolted right on. The newer pipes have a slightly smaller(or larger can't remember) inlet. Should work if you get the exhaust flange as well.
F ferguscawley New member Jan 12, 2009 #4 An 06 pipe will fit OK. There is a difference in the 07 and newer pipes. It will still fit but will take some 'persuasion'.
