08 EC 300 Lower Pipe mount crossover
Marc
I broke my lower pipe mount and looked on the cross over page and did not see a crossover for the lower mount. Does anyone have suggestion for something that will work?
Thanks,
Marc
Alloy framed yz 250 upper pipe mount is a direct bolt on. Mount,bushing, gromet,washer, bolt and nut. Pricey, but bullet proof. Just to clarify, I am referring to using the Yamaha upper mount for the lower mount on the GasGas. The stock GG unit is crap. I have even tried drilling out the threads and using a nut on the back side to keep from turning the rubber out of the plate, but it still separates over time.
McMaster has the exact M6 replacement for the pre '12 lower mount. I use the same parts to mount my shrouds and just ordered more for my friends bike.
54603048100 - range change metal nut m6 $4
50305012000 - swingelement for exhaust pipe. $16
this 2000 part only uses a screw, no nut on the back, unless I guess you wanted on and an extra long m6. this one is threaded all the way though, I just stuff some blue loctite on it. I just 20 minutes ago broke mine on the GG and was going, oh shit, oh shit, then I remembered the spare KTM part :)
How did you use these to mount your shrouds? Do you have a pic? My shrouds have just now started popping out in the thick brush while beating a new trail in.
