13 300 replica help
rvktm
parts crossover what shock guard fits ie kx cr .air filter is it the same as my 05 ie cr .do 48 mm wp /ktm fork seals fit 48 marzocchi . that lovely air box is best to cover the vents on the side up .all the rivets have come off in the upper part of the box going to silicone and 4mm bolt it . is there a better option for the rear light and it needs a speedo cable sensor any options should the speedo stay on not lit up. iv fitted a new battery in it .is that ok . should the cylinder head have a stay , brace to the frame like my 05 98 thanks
I think a 2011-ish 300xc fork guard fits. Although the GasGas ones are split on the back making it easier to take on and off. No head stay. I sealed up the seams on the airbox but left the vents open. If you want to make good power you have to have air...
Where are you located? I've had no problems getting plastics, fork seals, and air filters etc for my '13.
The Honda crf450 2009 48mm KYB forks share the same seals and bushes as the Marzocchi 48mm's.
