13 Linkage Bearing kits?
andykr87
Dealers are trying to sell me everything seperate. I guess there isn't an aftermarket kit yet for the newer style? The synergy seals kit doesn't come w new bushings from what ive read so I'd rather go back w needles and new bushings.
I just replaced Headstock, Swing Arm and Linkage with All Balls kits. Could have done it cheaper but couldn't be bothered stuffing around. They supply everything you need bar grease for my older GG.
The swingarm bearings and the linkage bearings are the same. Jakobi noted in his post that he thinks the swingarm bushings are the same as well. The quality of some of the aftermarket kits is questionable.
The swing arm bushings are different. Bearings are all the same size. Make sure the linkage you have matches the parts list. I have a 13 but it has the 12 linkage.
I hope sharing my personal email isn't a violation but here is what I got from all balls to cover my 2012.
Here is what I found out:
The bearing is 40-3038 you will need to order 6 of them. $3.80 each
The Seal is 40-4091 you will need to order 6 of them. $2.70 each
I have one of the pins, it is the one that is 14x22x57, the part number is 40-2225 you will need one of these. $7.95 each
The other pin and washers are slated for future development and we have the samples but we have not had them produced as of yet.
You can order all of these from your local dealer or on the web, just click on the order by part number button.
