Prepping bike for season, first time linkage checkup.
Linkage movement hard, opened, nothing problematic, cleaned, regreased.
Tested in vice, to check free movement - hard AF. Both connections.
Linkage links are moving fine.
What I realized is, that the large washer, being 0.9mm is too thick and it grinds into spacer.
Bushings should be just a fraction longer.
If remove only one of the two washers, spacer falls in too much, but free movement is obtained, if held in hand. If it were bolted with washer removed, it would be alu-alu grinding.
