2 finger clutch lever
Gregarious
Does anyone know of a 2-finger after-market clutch lever? I'd like to keep my stock one un-altered as a replacement or in case I end up not liking a 2 finger lever.
When I last ordered some parts from GoFasters they mentioned ASB (if that's the right name) might be making some.
I have a shorty clutch lever I purchased from my local GasGas Dealer.
It's an original part you should readily be able to get....
i run a longer lever and just slide the resivor up the bar about 2.5 inches
so you only use 1 or 2 fingers on the lever and its makes it a heap lighter too
Doesn't the lever hit the collar on the grip?
that doesn work to well if you ride tight trees and have to cut the bars down and are running bark busters. I ordered a shorty lever from the local gasser trials dealer, it turned out to be the same length as the stock lever. Don't know if your going to find anything much shorter
