stainlesscycle
here's an updated price list: parts on this list are available now.
these prices include shipping to the USA . international is more.
2000 excel front wheel (no rotor) $125
front brake master+lever+stainless line $50
rear brake master+reservoir $40
rear caliper+carrier+stainless line-brembo - will fit all models - may need spacer washer for newer models (i will include if needed) $70
swingarm (new bearings with 8 hours on them) $75
swingarm pivot bolt (new nut) $25
122mm ltr links $50
cdi (200cc) works nice for all models - not dual map. $100
ignition coil $30
Seat (99) blue factory cover, in excellent condition. will not fit 00 or newer. $50
seat (00) has been recovered - cover has tear or ten. foam is decent. this is the 'lower/wider' seat $40
complete clutch modified for cr250 plates, with new cush, basket drilled for oil flow.. complete with milled spacer, hub/basket/nut/plates (newish). everything you need. never squawked. $100
clutch master/slave/lever - rubber boot in master pluger is loose, but this works fine. rebuilt 1 year ago. $50
WER damper + mount $125
gnarly pipe no guard (from an 07 300) - has big dings $75
gas tank (04 i believe - has the recessed trials type cap- not the one pictured!) $65
aluminum subframe (needs welding - has repairs) $40
ALSO AVAILABLE:
99 forks (right side ups) $125
99 triple tree (right side ups) $50
99 300 bottom end (doesn't shift - haven't investigated) $200. no ignition.
various yellow plastics - some in excellent condition
.40 wp springs (i think..) - for under 160lb rider... i cannot remember rate, but i know they were too light for me. $40
122mm ltr links $50
ignition coil $30
ALSO AVAILABLE:
