REVERUP
A couple pics I took of things you might be interested in seeing if you haven't updated your Gas Gas for a while. The evolution continues and yes the factory is listening. I took these today while working to further set up my 2011 300E.
Roscoe
New and improved coil mounting much more rigid and protected, not sure heard grumblings it may interfere with adding aftermarket larger tank.
Air filter changes a little less roomy with the E start but still very doable.
They really have went to great lengths to try and lighten things up recently. This new frame design has signs of it all over. Here is one instance I found that is pretty substantial. It may also contribute to chassis feel. They really shrunk the euro steering lock mechanism down also.
Threaded brass inserts in gas tank
Roscoe
