desertgasser300
Banned
This idea was gleened from GMP so I will give credit to him. I am just merely posting what I figured he had done to re-attach the shrouds on the 12' bikes. There is minor drilling involved to make a hole in the shroud for the new bolt.
Unlike others that have had a problem with them popping out while riding, I did not. My push tabs on the bottom shroud mounts finally broke off from several get-offs.
All the bolts and nuts used are m6. I had to remove the rubber grommet from my radiator to have enough clearence for the nut, but only because I am running rad guards. If you do not have a rad guard you may have enough room without removing the grommet
Here is the link to the parts I used....http://www.mcmaster.com/#catalog/119/1375/=ly3lmz
Part# 9232K16 I went with natural rubber, there is an option for neoprene as well.
The part and all the crap in the back ground!
The finished product
