2019 bar spec
taylor146
hi,
I have a 2018 ec300 and I am considering replacing the standard bars with a set like on the 2019 without the cross brace for a bit more compliance. does any one know what the direct renthal replacement is for the 2019 type or is it safe to cut off the cross bar on the ones I've got.
thanks darren
I have both and i like the 18 bars better, if i get time at weekend i will see if u can do a straight swap and let u know
Many say that if you want to keep the Bar Pad you can cut the brace (which allows the bars to flex more) and put a little sleeve over it.
Jeff
