20mm Front Axle Spacers
Mattnzl
Hi - for some reason my 2007 ec250 has an older 20mm diameter front axle (found this out the hard way when the wheel bearings I ordered didn't fit!).
Can anyone confirm that these are the correct part numbers for front axle spacers for a 20mm axle?
BC250018018
BC250018019
It's doing my head in looking at the fiche pictures, as they all look the same and make no mention of the axle size :(
Much appreciated, Matt.
Just answering my own question for the benefit of anyone searching in the future: The above part numbers are correct for the 20mm front axle.
or 6004 rs front and 6005 x1 and 6004 x2 for the rear
you can find the numbers on the side of the bearing and use a bearing supplier its cheaper
