Hello Everyone !
I am new to this Forum and pretty surprised to see the success of Gasgas bikes all around the world !
To introduce myself briefly, I am a 24 year old French dude and I've been riding Gasgas bikes in the past but trial ones.
My new (and first) job brought me here :
If you zoom in, you'll discover a wonderful playground around the mountains. It would be a shame to not be riding here !
I've always had this old dream of a big two stroke supermoto on the road (the best bike I had was an Aprilia 125 MX with the Rotax engine) but I never took the step. Shame that the road legal 500 CR became quite pricy !
After serching for a while, I found that the Gasgas 300 EC could be the perfect fit. And I'd still have the possibility to switch back to enduro wheels and have fun in the dirt.
However, to use this bike on the road, I would need to know which rims can I adapt.
I've read a lot of posts about this subject but I couldn't find any actual dimensions. I even sent an email to Gasgas but didn't get any answer.
The idea here would be to get 17" wheels adapted easily without having to buy the 1000€ Gasgas ones :
http://www.motocrosscenter.com/shop...rd-gas-gas-17x350-y-17x425-be55400sm2510.html
So, if you guys could help me to sum up which rims from other brands can be adapted without mods that would be great.
If there is no precise list, the other option is to get the dimensions that have to be checked when buying a used set of rims.
I am looking for a GasGas model after 2007.
Could someone provide me those infos ? (Just ask me and I'll make a drawing of what I exactly need)
- Wheel axles diameters. I have been reading that the diameter changed somewhere in 2004. I think it is 20mm at the rear and front. Other brands may have 22mm or 25mm so this could be a problem.
- Width of the wheels hubs (from one bearing to another)
- Dimensions of the discs supports
- Dimensions of the rear sprocket support
- Width from the disc support to the sprocket support
- Width from the sprocket support to the next bearing
Or could life be easier : who managed to adapt a set of rims from another brand without modifications ?
Someone from this forum (Gassergrant) adapted CCM wheels without much mods, so I guess those wheels could be found on other bikes ?
Here is the thread : http://www.gasgasrider.org/forum/showthread.php?t=16956
I found the max width of the rims : 4.25 for the rear and 3.5 for the front.
For the rear tire, I found the info as well, it is 150 maximum, otherwise it will rub the swingarm.
The second point seems to be a big matter to me : the front chain sprocket.
Using such a bike on the road will require to adjust the transmission. The stock front sprocket being a 13 teeth, can I switch to a 15 without grinding the hydraulic clutch module ?
And why not a 16 ? Who would be able to give me some feedback of the right ratio to use with 17" rims to cruise comfy on the road at normal speeds ?
The 15 teeth is available here : https://www.3as-racing.com/A-242503-pignon-acier-jt-gasgas-200-250-300-400-450-cc.aspx#.V1RyEUtu2Qs
I remember about reading some posts from Jeff on this forum. Jeff if you're around, do not hesitate to share your experience / feedbacks
Any other info about SM conversion on a 300 EC is welcome !
Btw, is there a key on post 2007 Gasgas ? I think there is a lock on the fork but no "ignition" key ?
Thanks a lot guys for your feedbacks and answers !
Greetings from France.
Antoine
Antoine
