300HP Wiring Diagram?
300 hp wiring
cmon people i need one of these 2 as my fan doesn't work and im lost as far as this bit goes, i can't work out the electrics from the motor side.
Hi,
The wiring diagram is inside the user manual, for instance, for 2005 ym is in page 64.
The manuals are available for download in www.gasgasmotos.es. Click "Manuales" in the left frame and select the required vehicle in the top.
Regarrds
Thanks, but I have the 04 300 Wild HP Reverse. I have that manual in paper form and as a PDF file. No wiring diagram. I obviously don't check this forum very often.:o
300wildhp wireing diagram
Hi has anyone got a diagram for a 2002 gasgas wild 300 ,can't find one anywhere ,cheers garry
I dont have a diagram,but I do have a 300 wild.I would be happy to check what you need,its cut though,no horn,lights ect.
Hi jim could you possibly send pics of wireing loom and what the wires are attached to from ignition stator connections to lighting stator connections or if easier list wireing colours to each part . Thanks for any help on this ,garry
Hi jimjim would it b possible to have a look at the wireing from the lighting stator and let me no what the order should b , I have wired mine up but red wire gets hot after a short time so have no been able to use . Thanks garry
