SOLD
Recently serviced
43mm WP forks lowered about 1.5"
Progressive springs of proper length (about $100 new)
These are in great shape and work well for the woods. The lowering can be reversed if desired, I have original springs (plus dimantle to remove internal spacer)
One compression damper nut face has some damage, but still can be removed. I will include two good damper nuts.
$200 OBO (plus shipping)
I also have tripples.
These probably fit KTM models also, I just done know which ones.
If you want to lower a bike, but still have the stock setup - then this is a great way to do it.
Using the Kouba links for the rear and this on front worked great.
Recently serviced
