48mm fork springs
nato
I have readily available a set of .46 springs that measure 460mm in length does anyone know if they will be ok for the 48mm cc zokes?
Cheers Nato
Ask Simmo he had his apart recently hopefully he has the measurements. I have a feeling they'll be about 10mm too short unfortunately.
Stock was 475 with 5 mm preload, I think there were 4 preload slots, so you'd need a preload washer of some sort to make 460 work or you would end up with zero preload on the lowest preload ring. You'd better look at the manual for preload rings, I'm at work next two days so can't have a look. The kyb springs were 470 that Steve sent.
Cheers
