2 strokes 4 life
Bike: 2002 EC250
Mods: LTR jetting kit with 42 pilot jet air screw 1 and a half turns out
Backround Info My bike was running fine up until last night when i decided i was going to go on a ride. The trail was rooty and and lots of gravel up hiils. I reved the bike fairly high up those hills and bogged it on the roots befor that. Once i was at the top of the trail my bike was boilling big time. I lost half my anti-freeze. I decided to push my bike home just to be on the safe side. When i arrived i kicked the bike over and it started fine and ran well. I then thought it would be the plastic impuller that was the problem. I also noticed that my bike has been making very loud mechanical sounds when operated in the lower RPMs (not sure what this is).
Inspection: I saw my air filter was somewhat dirty (cleaned the ride befor this one), took out spark plug and it was a light brown almost white (sing of overheating?), took off the ignition cover and there was a table spoon or so of water, took of powervalve cover and there was lots of oil and black spoonge or carbon, took off water pump cover and nothing is wrong with the impuller, i have yet to drain the oil because i just replaced it the ride befor, lots of crap gathering near the powervalve drain off tube and on the tube it self, and thats about it i think.
Questions What is or could be my hot running issue, what might the lower RPM sound be, what should i clean the power vlave with, what should i clean the ignition with, and i think that is it.
Thanks for any help you can send my way.
