abc
jakestein
hi i would like to know what is ment by a b or c pistons?
i no that you need do do an over size on worn cast iron bores and get the right piston to match.
but the gg has a crome plated bore or the like so why the different piston sizes??
when you would just get it recoated to the original specs.
a,b,c.
each cyl. will be slightly different in size. they match the best pist. to each particular cyl. most bike manufacturers do this now. and if your getting a cyl. replated you would send the piston with it so they can plate it to "match" no matter the size. i send cyl's. out to be plated all the time.
