Adjusted pv now i have an oil leak
puttyhead
Hi all
just looked at my pv and adjusted from tips on this site.
I now have an oil leak underneath in middle. Bolts were torqued and tweaked a bit more is there anything i can do other than strip it down again.My mechanics is limited and must say this job was harder than i was expecting.Sorry should have said its an EC 250 2003 bit stressed.
Hi all
I'm going to guess you removed the clutch side of the case. All you can do is remove again and check for debris or broken gaskets.
Hi desertgasser
yes you guessed right.Will have to take it again tomorrow.
Just a quick question inside the cover there was a mark possibly where the pv was rubbing is this expected with the rattle.
