I made a custom tool for spinning the ring, no banging. Basically a plastic coated pry bar with an end ground to catch the notches well. You just pry against the frame. A tire iron can be used in a pinch if the spring trick doesn't work.
Next ride when your all geared up, you and your buddies check each others race sag.
