W Wypipo New member Dec 31, 2018 #1 Is there a reason that one of the preload collars on kyb shock is made of aluminum? Can it be replaced with a steel collar?
gasgasman Super Moderator Staff member Dec 31, 2018 #2 Probably cost. Cheaper to make that collar out of aluminum. Do yourself a favor and install the X-Trig adjuster.
W Wypipo New member Dec 31, 2018 #4 Ok I will check out the x-trig. Does it replace both collars? Are they bike specific? Do you have a link where I can order one?
gasgasman Super Moderator Staff member Dec 31, 2018 #5 I added the X-Trig preload adjuster to my '18. replaces both collars, no shock disassembly required. Works really well. The YZ part fit right up with no issues at all. 07-09 YZ250F/450 XTrig part # 10200002 Any GasGas dealer would have it.
