Hi Guys,
I have a 2010 ec300. I have been struggling with eliminating the power valve rattle. I have had the right side case cover off and adjusted bellcrank to have some slight tension on the actuator arm as all the posts suggest. The noise is significantly better but still there. Upon further investigation I have noticed that with the flapper valve and right side barrel closed, I am able to rotate the left side barrel a few degrees, and does make some slight noise. I haven't pulled everything out yet to inspect. Possibly a worn shaft or oval holes? Any thoughts or suggestions are appreciated.
Cheers, Jason.
Cheers, Jason.
