Out of curiosity, why don't you run rad braces/guards?
Wes.
Speaking of radiator guards, I have a set of Bullet Proof Designs on my 300. Will try to post some pictures a bit later.
Actually, the only real problem is getting to the bottom radiator mounting bolt, since the lower shroud nut insert doesn't allow you access as the older model instructions state.
I have managed to twist one coolng tower on my 99 EC200.When I replaced it with direct KTM repacement....I take it GasGas no longer used KTM coolers?
Will Mylers weld all the seams?
