Just for reference for anyone else I got a full athena engine gasket set for ?35.38 from this place which was cheaper than athena direct,and most certainly 40% cheaper than GGUK
Good job.be aware the gasket set does not have the coolant hose/head gasket in,wont matter if you left t junction on head but if you tore it (like me)removing the 't'...also the oring/seal on the coolant drain plug is fragile,might pay to replace
I left the T on didn't see the point in taking it off,no leaks so all good.
for the pennies it costs for 'o' rings im going to change lock stock the fu....ing lot.
