Axle Size Gasgas ec 125
Noobi06
What size is the front and back axle on an EC 125?
I want to apply KTM supermoto wheels and rims that fit on a 26mm front and 20mm rear axle.
Check the bearing part numbers for the year bike and work backwards. For the older 2001 to 2004 the 125 wheels and axles were the same as the 250 and 300 bikes.
I would guess 25mm front and 20mm rear axle diameters.
Adapting the front is normally mostly a matter of turning some spacers or replacing bearings. The rear is usually more difficult.
