Backfire Won't Start FSE 450 03'
purplesda
I have FSE 450 2003, yesterday I drove into a puddle and bike turn off as if he choked .. when I start, it shoots in the exhaust. Bike is after renovation 40 mth , I checked the valves are ok, the fuel its ok, the spark is, new candle, timing gear its ok. I think mechanically is good. the third fuse from the fuel pump was burned. is a program that shows errors where to look? any advice, I do not know where to look
sorry for my easy language
This is what show me program, last faults.
Now I removed all faults. Tomorrow will charge the battery and try to start the engine with the program on.
zSaHLL77Ukb5xNR6-1Uzvu79RZ1oryOPsSyze28gCh01yOvlxeCaK1HS8xw_zzTzNpCAWCQVPRe6LE3muBEXI_xiYMmaFoXr0K06WokqKBF8fTeE4UdOZd0BIed5A21uLF7z7D99PfFam524RuFDtjlespg2DaCJcJI3Bw_cD38q1l9w-A-KvAhgy1jlHcriDI7MmUgRBY8K_Fb4Zf2O3CpBZWr8vq4iWnzL_CmdmoeQ6tWY7cXEccNwXazPHX3pW01l5FiVpf9k5NncqPzPzEppgP0YnKfV0WgpIyUxNAKYDGXC0oc7_wImJbiUV3Gon3STnM3Uf9ZWEXeOMtd2_j7CTJw3llX4OimAshoo3nUbCm_sGCfY-UBSWMgsWOSL1BoZwmQeYTY21Apk5lTyIVM4gNWHZgk6sHul7i4mvwhpYb4UKrbfXZSRMsVkf8onpz1VgXbgLD2Xg52Hsr6xVjI3x1tg7mwnmEErtE90nqSGJ1VQDDAuVVU7jl7yUCeQh_iyf9TdApUEc8nZno9IfYA8Xlw5ii41XNNmbipURWBwisX3DnqGBY-xi1BZvmywfAHXsgYjfehrxzCComMjY7ojzU-zA4LvcDqvzEFDt_GKQCu7qTqQcHoVUZkx6sICXRsnokN1rUXPHUOljQtLeGMN=w854-h618-no
It did not help, it still shoots in the exhaust.
Statistics on the engine turned off ..
yaQtCCCBgez6zQckalUlwpCE15WaSGQY5Z6pVrdq-r6WT4lStbVeSxnCGl1p3q61kLbQOZa3QjcDZ9ACP6ueku8g5WIjpAC2PE5PYibsn3BDOfFsaOdAavbeY7_FUTVfQ3AFXX8ItBFM8h6ZP_QlNSocqUagBvdEz-FiAtXexXl_7ptsv563JUx4VffRtFnvQnGtV17jKOYs8WDDKXIFD3BmvA5PNUGzwpZx_WC5nNuzPscHYFYMA9XaP5-Lhvbz0fv-uRJSx1hhBqeJ_RBPlWcQ8k8sWvgCwVYfsU0l2LYXMU9tzERA2qF1YUHdCqtFyGynVtgLOcHAkJs3jrDaY0aR3GMiiWabdydQrvmnEp7j7xtttf7wrzrbswk4r3xacuTjd8uMha6ch5FU__Swva07KxnqjVs2iDlZ-uXZoeJ7bEqMhk76lJjjmR0WSwVSdjGWeZ6C1DWtlA3ahextQm34l77EhmTwsgjgwbe5OmK53cjcJ6oEcOtWGx5HCZI12AuP3LVG534vDj9Uyyv_UGqAfB5Avxa5hWI-kPl3ur9jIeM4La3tY_lm8C5HmQBgWoYbZRmDzXf-SYwMze-MLF0cW76A58EqcNJU8RTD6wgidx6FrwbUTn7H9FwNup-3cAKYciGlfkj86TrJ9omGgmtK=w864-h625-no
Here during the start .. faults no longer show
RZLMvB3w0rWSUUw9tuh9uPA9n-AHRFVsEWggHPwPCLb6lc6Qm8bhR0FElMJW2u9rfg58Zl3nim5euJwArLTRBzy9u5HLZlTAatRb9rcDuzdlyw4hMKV6iio1_CooFF0WboiUhA8DMeCN9DQvXyjaiA0bhe37vvkosqwth_4p3dyxdT840Ro9TV2fATIr_ouV00OwSJGSflJ82ltof66iakH_DItBJcxGfznKDDlDQPouuMsJOldKeFWqIa-R6cxAmfxxDsJDitjWKZnuWMMlunWhDUls0s1CtKZxYLQSIJ0QlkSwIQl31fQx2V7n1PIaUI-lH9lZqpKjpjHztmXSmncGiJ79K536EWl6RoGf1_h0Mih6vGLmn4sUXSD45dhsybLzjFO1sinbZFZixtjkmg6Gg-oBgpho9Rw0ailkxeOcbujja8uH8-MLZaOep6DVoSQR6gmOj8oofHiC23nqWRNUm7lmxrwt3fJ6verSHRzrEfgJ8ky4YXReazXdpbvKvyIXE-KaSfSsF3XMc-2OvPm3I2O1-2vcO1OwH88pcS3o18tFDSvnynIR5z1r3e294k9K8U4KFAcUEcSGAwsHIn-q4rj443IYm-orxamBxMvvN6CkRgy6VT3Z1cs7WtTLzx4uOD313YfwW-mbFdEM0SBb=w856-h643-no
maybe it's a voltage regulator? for a small voltage during the start?
