Base Gaskets
I used the 5mm with a thin bead of Permatex wich comes to approx 15mm.Reason for sealer is so my front 2 studs would not leak.That was a year ago no leaks no problems.
I think the procedure would be to establish the squish band and, based on that, decide how thick of a base gasket to use. It seems the factory sets them up a bit conservative (thick) and many here have gone to a single .3mm with good results. I think I even read that a single .15 was used but it carries the slight risk of not being thick enough to get a good seal.
Trying to correct the squish with a thinner gasket does not work because the problem is the match of the head to the piston and lack of consistant clearance across the squish band. The thinner gasket will add compression and reduce the clearance, but the effective squish is a function of both the clearance and match to the piston. For example, you could have a decent clearance of 1.5mm near the cyl wall that rapidly tapers off to 3mm+ at the dome, so you see little gain. Thats why the head must be cut.
If your not going to do the head, just drop in a .3mm or .5mm and be done with it, it doesn't make that much difference. The stock squish is sloppy enough not to worry about it. I dropped .5mm from stock(.3mm and .5mm) on my '03 250 and still had close to 2mm at the cyl wall.
I think the colors may have changed, but in my kit, .5mm is grey, .3mm green, and .15mm light brown and obviously the thinnest.
I just got some base gaskets this week. According to my calipers the green one is .5MM, the brown paper one is .15MM. The old one I took off was green, I did not pay attention however to the relation of the piston dome and the port openings with the piston at BDC before taking it apart. When I re-assemble it I will check the results and post them.
Like Glenn, I found the stock squish band to be large.
On my '06 EC300 stock I measured 2.2 mm squish near the cylinder wall and 3.1 mm near the edge of the dome.
On my '01 XC300 stock I measured 1.9 mm squish near the cylinder wall and 2.8 mm near the edge of the dome.
Taking out a 0.5 mm base gasket will help a bit. However, to correctly fix the squish, the head needs to be machined.
Also note, when you put in a new piston you need to recheck the squish and adjust base gaskets accordingly. When I put a new Vertex piston in my '06 EC300 I measured the squish band with the new piston. I found the top of the new Vertex piston was 0.2 mm higher than the original piston. I compensated by increasing the thickness of the base gaskets.
Here are the results from my recent top end overhaul. I had the cylinder replated to A specs. and a Vertex piston. I used one green base gasket that measured at 0.5MM. I did not take any precise measurements after assembly but, at TDC the top of the piston was approx. 1.5-2MM below the top of the cylinder. At BDC the top of the piston extended about 1-2MM above the lower opening of the middle exhaust port.
I just did the top end on my 300 and used a .3mm (.012") base gasket, same thickness as before. It started on the first kick but, Now I have a small coolant leak on the front side of the jug.
Would gasket sealer (spray type) work to seal this? Both surfaces are clean and free of scratches.
Or go with a .5mm gasket? squish has been set with a .3mm gasket.
Thanks!
I always use a light coat of gasket sealer with any gasket. Make sure that the center case gasket is not protruding and the surface there is flat. A little extra sealer there and at the rear joint won't hurt.
this was going to be my first question on the forum, as i noticed today my bike 03 ec300 has 2 base gaskets fitted,so this is standard then??
Just pulled the top end off my '09 300R as it came stock with 3 base gaskets in it (0.5, 0.3 and 0.15) and replaced them with just the 0.5mm gasket that came with the spares. My question is has anyone else done this to their 300R, what sort of difference did it make to the power delivery and will it increase the compression too much? I have yet to get the head machined to get the squish band correct but will be doing that when i put a new piston in later down the track.
Cheers,
MM
I could have used just the .5mm, but used the .3mm and .015mm as the parts manual said. Mine came with the .3mm and .5mm. It made a world of difference and really made my bike run way cleaner.
