hi folks,
so im trying to rebuild my ec250, but i have discovered that the shifter shaft is bent, just out side the engine on the shifter side.
i was hoping that removing the nylon bush on the clutch side would free up the shaft enough to remove it, but it dosent...
can anyone tell me if the shift shaft is run through bushes cast into the cases?
if so i may have to cut the outside end off in a hope to remove it...
any advice? suggestions?
