These are pretty popular with the orange crowd and are now being made for Gas Gas 2Ts.
http://www.bulletproofdesigns.com/gasgasguards.htm
GMP said:They do look nice but forget about bling for a minute. What do you see that makes these potentially inferior to the flatland guard? No tie back to the head stay, no side coverage, and judging by the hole placement they sit much closer to the radiators, which hurts airflow and provides less room for front impact damage.
For less than $100 you get a set of Flatlands, add TWO sets of GP braces for $60, adding an upper shroud mount.
For less $$ this is the most bulletproof radiator protection setup you can get. I crashed hard enough last week to flex the right shroud to the point of breaking the brake fluid resevoir. The side of the Flatland guard was bent toward the rad only about 3mm in the center between the GP braces, they did their job. The shroud was fine, the rubber isolator I use for the upper mount separated and was eaisly and cheaply replaced.
GMP said:They can clog with mud, but most of it clogs the guard not the radiator, at least not to the point of ever causing me a problem. The GG has excellent cooling capicity, unlike my previous KTMs.
Do you use an upper shroud mount? This saves plastic for sure.
d2w said:Hi
Could one of you with the GP Rad Braces please post a pic of the unit, or provide some dimensions of it? I'd like to see if it would work *with* my existing billet guards.
Added strength would be good.
I despise the little held-nut mechanism for the lower shroud mount.
Specifically:
1) How long are the male threads which attach to the frame (since the billet guards are quite thick in that area)?
2) How do you screw the braces in in the first place? Is there a flat which you can grab with a wrench?
3) How long is the tubular part of the brace?
Regards.
Dale
