GMP
Active member
OK guys. time to help me out if you can. '07 EC250 with Nissin integrated resevoir rear master cyl. I cannot seem to get this thing bled. Right now I'm thinking I may have a bad piston cup seal and will take it down tonight and check. Before I do, are there any tricks I'm missing? I've done countless Brembos and other Nissins but none as a PIA as this. I've put a lot of fluid through it backwards, backwards while cycling the piston, and drawing it back through the caliper. No bubbles evident by any method but obviously there is big air in there somewhere.
