This is the condition of the reeds on my 04 200. I see there is a slight gsp. Not going to replace them just yet. Can one reuse the gasket? Do the reeds get cleaned at all?
Your reeds look fine, I don't like reusing gaskets, but if it's in good shape it will probably work just fine. I don't think you want to "clean" your reeds maybe just wipe them off.
One screw looks loose though? Maybe just a camera angle.
It is loose as I only loosened the one side to see if I flip it over if the gap at the tip would close. Got some blue locknut stuff to use with the screws when I assemble.
