Brake lever tip / tab
I just put one of those on a aftermarket brake lever I had bought for my 2011 and it fit perfect, I could check to see how it lines up with the stock lever this weekend if you can wait.
did you end up getting anything else? could either of the holes be opened up?
I'm sending it back. There's no way to make it work. On a steel tip, you could drill the holes bigger.
This is on my '18. I'm not sure how the fit would be on prior models.
Hi Dan,
I am confused a bit. Did you order just the tip (like $19.99), or the entire brake lever with tip. the link you sent is the replacement tip for a TUSK aluminum brake pedal.
To answer your other question: Yes I would love to know if this fits on a stock 2011 brake lever.
I ordered the tip, it fit what is on my bike which is a aftermarket pedal I ordered from some place in Europe a couple of years ago. I'll pull the stock pedal out tomorrow if I remember.
Here is the link but there is no picture. It does fit the stock pedal and is much larger than the stock one. Also it is offset out a little so it doesn’t hit the clutch cover. It’s really nice but I lost mine when I ripped my whole brake pedal off.
https://rekluse.com/product/brake-tip/
