Here is my problem. I have a 2003 FSE450 that is having a difficult time starting. I can kick start the bike with some difficulty but the electric start only turns it over until the motro builds compression.
So I checked everything I could check and came to the conclusion that auto decompress is not moving the valve far enough. The bike only has 294 miles on it and the decomp mechanism is working fine and the valve clearances are all good.
So my questions are:
1 Is the decopression mechanism replacable
2 Would a later model cam fix this problem
3 Is there an adjustment to cure this.
Anty help or advice appreciated
Paul
P.S. Below is the response I got from Yoshimura Japan about using a DRZ cam.
Dear Sir/Madam,
We are sorry for our late reply.
In reply to your enquiry, Gas Gas used to buy our DRZ camshaft, and installed it to their motorcycle. We also heard the camshaft fit FSE450, but we are not confirming the camshaft installation by ourselves. Because Gas Gas motorcycles are not imported in Japan.
We are sorry for our unclear information.
So, if you would like to install our camshaft to Gas Gas FSE450, please install it by your own responsibility.
Thank you very much for your confirmation.
Best regards,
Yoshimura Japan Co., Ltd
Paul
Dear Sir/Madam,
Best regards,
