Ok, total noobie question on the cartridge. I have the fork cap and spring out on one end. I have the base valve out of the other end.
Does the cartridge unscrew from inside the outer leg or should the cartridge and damping rod just fall out? Is this what Steve B. was talking about when he said 'special tool' ?
The cartridge is very tight inside, nothing but the damper rod is moving back and forth.
I am changing the fork oil, and attemtping to tune the base valve stack some. I wanted to get the rest of it apart to tune the mid valve using some previous suggestions as well.
*****************NEVER MIND, I GOT IT OUT, JUST A LIGHT TAP...*************
Now to figure out how to get the stopper out of place with the peening... damn...
