blitz11
Greetings.
After 7 weeks in a cast with a broken wrist, I was able to ride. On Thursday, rode 20 miles, bike ran great. Rode 25 Miles Friday, mostly 1'st - 2'nd gear tight stuff. Hit a fire road, opened it up, and it died.
Felt like no spark. Pulled plug, no spark. New plug, no spark. Towed to trailhead. Done for the weekend.
Yesterday, tested the bike. Stator measurements good (100 ohms pulsar resistance, 27 ohms exciter resistance). Spun motor with electric drill, see 35VAC at the exciter terminals, and 350mVAC at the pulsar (which i would expect as the RMS value will be low). I didn't have a scope or A2D at home, so i couldn't measure the waveform. But, on a gut level, it seems OK. No corrosion at the stator/rotor. Looks clean. Main bearing tight.
I plug everything back together, check and WA-LA! Spark.
What the heck? I kick the bike, and it starts, idles. I can't rev it up 'cause of the neighborhood, but it seems good.
Anyone seen a failure like this?
It doesn't seem (but could be) to be a heat deal, 'cause it went 25 miles before it completely failed.
I am going to build a arduino-based CDI this fall. That way I have a spare and won't stranded again.
That might be worth a tech article.
Any insight is solicited.
Thanks.
blitz
Thanks.
blitz
