Changing fork oil in Zokes?
ktmguy23
I am relatively new to GG, but I just bought a '05 250 de. I did alot of searching on here and the web and cannot find anything on how to change the fork oil. I have done the WP 48's in the past. With those all I did was remove the cap, remove spring and guide rod and then drain the oil.
Also on the zoke can you tell me what to set the oil height at for east coast conditions. I prefer a plusher fork. Thanks in advance for the help.
I was on the phone this afternoon with Les and asked him oil level height for you - He told me you should go with 125-130mm oil height - manual states something like 80-100mm range; The usual caveats apply - assuming correct spring rate, you don't weigh as much as a piano, and you aren't supercross'ing it between enduros, etc. etc...
