Clip position ?
thingymijig
I ride a 2002 250 EC
Can anyone tell me what the clip position actually does, The manual recommends my set up in the central position. What effect does putting the clip higher or lower have ?
My settings are
Needle N1ef
main jet 178
Pilot 38
slide 6
altitude 300 ft above sea level
Does this set up look ok if not what changes would you make ?
Thanks
The needle affects fuel flow mostly from approx. 1/8 to 3/4 throttle.
Raising the clip on the needle leans your fuel/air mixture in this throttle range and lowering it richens it.
The needle restricts fuel from being drawn through the needle jet. As the throttle is turned it raises the needle out of the jet, progressively allowing more fuel through.
Still rich
Thanks for the reply Brian
so by this i think i shoulld put the clip on the top cut away, as it seems to be missing and spluttering still (too rich ?) even though the jets and needle are quite lean ? and the air screw is out 1 1/2 turns. Would changingh the slide from a 6 to a 7 make much difference ?
Thanks
Go one clip position at a time. Try the #2 position if the middle seems rich (positions count from the top slot down).
Yes, a leaner slide will effect a similar opening range. Much like changing needles.
Have a read through this
