I took my 2003 ec250 out for the second time. It seems the clutch is not always letting go which kills the motor and makes starting in gear difficult.. Since I'm the new owner I thought I should try a lighter gear oil, but I also took the clutch cover off to inspect things. I see some wear on the clutch basket and inner clutch basket. On the outer clutch basket fingers I can feel and see the wear. On the inner clutch I and see wear but I can't really get my finger in there to feel it. I can't feel it with a pic.
The steel plates are flat and the fiber plates measure between 2.75 and 2.8mm.
Is the clutch basket worn enough to need replacing???
