clutch lever (unbreakable ...)
RGG
I just get a 2008 EC 300 and i would like to know if anyone knows where i can buy a unbreakable clutch for this bike...(asv or other). I tried the magura ones and does not fit. I have to buy in internet cause im from chile.
Thanks..
Rodrigo.
Just use a bark buster.............
or dont fall.............
je
you can get flex levers on ebay, but they arent cheap. bark busters are a much better bet. loosen up your levers a tiny bit, so if you fall, theyll rotate around the bar instead of breaking. ive also scored the lever at the minimum point you need to operate it, then if you eat it, the whole lever isnt gone if it breaks., ive also seen guys heat thew with a torch, then curl up the end( at the same part youd score it) so the bar itself hits and not the lever.
Take the perches off the bars and wrap the bars with teflon plumbers tape. Remount the perches and tighten to your liking. The controls will rotate before they break. I also drill little relief holes so just the end will break off though I have yet to break anything since employing the teflon trick. Bark busters help alot as well.
Paul B
je
I got mine and drilled a small hole in pretty much the place where you'd score it. Don;t know if it works though, never broken a lever on ym Gasser, and its been at least a year and a 1/4
Hebo Levers.
I have bought several Hebo Levers. They seem to work better than anything I have ever used... They have a pre-scored nub on the end and that is all I have ever had break off. They are about $30 bucks. I got mine from North Tahoe Motorsports and have been happy with all of them.
