Clutch master cylinder
mjtursky
Looking for options to replace the stock AJP clutch master cylinder assembly. Any suggestions for a direct bolt up? thanks in advance.
Motocenter AZ has the BrakeTec (who, somehow, acquired the assets/IP of AJP) rebuild kits for the AJP master cylinder. My MC is 20 years old w/o a rebuild, but i have a kit just in case. Much cheaper alternative FWIW.
You need to pay attention to and match the fluid type unless you want to put the corresponding seals into the slave cylinder too. Magura and Brembo have other options.
I would suggest a Magura, as they were used on Gasgas in some models. If you get one of the same type that was used as OEM, it should fit right in.
Thank you for the replies. I purchased a rebuild kit off E-bay awhile back and it did not function. I believe it was mislabeled for the fluid I required. The seals failed in a short amount of time. Fortunately I bought a used assembly and it has been working pretty well. Was hoping to find a newer more readily available assembly. The OEM doesn't appear to protect very well for mud and debris.
