I noticed this play in the clutch I bought second hand from ebay. Im pretty sure this is because of the rubber things in the outer basket that are worn out but I wanted to double check. Also how much does this really matter since the play is small. Some say it needs new rubber things in the outer basket,
Some say the play is small and its no worry:
Note: only outer basket has play, not small.
Nut is torqued down to spec
Edit: cant attach video from phone, will do later. Either way, clutch can go in and out (towards the clutch cover and back in). Around 1 mm
