Clutch problem :)
You have bottomed the slave cylinder. Just put your throw out bearing in and push it in. Should be good to go. Or just reinstall the clutch and it will push the slave back in
What can cause metal clutch plate breaking ? Firat metal plate on the engine side was broken. Clutch work just fine. I have some rattle, seams to be from power valve,my exhaust o-ring gone also.
