bluespark
Yesterday I had the RHS primary cover off adjusting my PV and inspecting the clutch plates. I put it all back together and didn't notice that the push rod wasn't extended up and thru the pressure plate(wrenching noob). There was no circlip or "clutch pin" when I first opened it up, and I didn't see any spare parts in the case when I had it open.
When I started it up it wouldn't go into any gear, pumping the clutch did nothing. I opened it up again and noticed my mistake.
It does seem from the pic that the push rod is recessed too far.
[/IMG]
Is the rod jammed up in the slave cylider?
I guess i'll open up the primary cover again and look for parts
