Clutch shim?
vaughan
Hi, i am replacing the clutch plates in my GAS GAS 300 txt, year is between 2010-2014... there is a spacer between the clutch fingers and the needle bearing, my question is which side of the spacer does the shim sit? i took it off between the fingers and the spacer but it doesnt seem right? Was wondering if anybody had a parts diagram? Thanks in advance.
The hell teams page had parts diagrams but I could not open them the last I tried. Think Paul needs to sign in to his google drive, the order is piston, bearing, then shim against the clutch fingers.
