Clutch Video
ramcclure200
Had some issues with clutch Sunday, lever would not pull in so I took video of the disassembly and reassemble process.
Also found out the nut backed off, the last time I had it apart i did not use loc-tite but I did torque the nut to 40nm (is that the right torque spec?) and bent the tabs over the nut (do the tabs need to be bent up or 1-tab up and the other down?).
Is the proper torque spec for the springs 10nm?
I included a video of putting oil in the gearbox, some of you guys that are having issues with funnels should try it.
Hope this helps some of you guys.
http://picasaweb.google.com/ramcclure/Clutch#
Please some one that has proper torque specs let me know.
Thanks
Ron McClure
ECDE200 2004
