Upyourkiltbatman
Anyone know when to change piston or rings. What would be a good compression reading ?
I just did a compression check on a cold motor. Kicked it 10 times and got a read of 175-180. Release and did it again and got the same reading. Bike runs great and I dualsport or trail ride.
Do you guys that know more than I do about engines, should I do a top end on it now?
Thanks.
PS bought the bike used and had carb issues but since I got that dialed in its a great bike. 2007 ec 300
A smart ass might say when they need it but you're likely at the outer limits at 120 hours. A piston rep once told me the issue is not so much the rings (you can always slap a new set of those in) but the piston skirt gradually collapsing.
The GG250s run about 185psi iirc, but the 300s will fool you with a super low reading because of the compression bleed hole (I recording 135psi on a new 300 and just about died before I knew this).
Some would say leak-down is a better measure of health, but at 7000 rpm, how much time is there for leakdown anyway? Besides that you miss the dynamic sealing action of the rings ... best to take compression numbers periodically and change the top-end gear when they start to slip.
compression tests are bull on a 2 stroke
Just pull the lid if the bike is new to you & clean the PV etc, measure free end ring gap while you are there, done in an evening & 2 beers. (Just read the instructions on melting the nylock nut on the PV arm, its all in the help bits on this forum).
Order parts if required & slap it back together, 4 beers (gotta stand round afterwards & congratulate yourself, but go upstairs before you have any more and decide its a good idea to test ride it).
