CRD radiator guards
lordfeyr
Anyone running these?
If you could take a pic of how these are mounted it would be much appreciated. I picked these up used and have no idea on how to mount them on my 04 300.
I have a set for 08, mounted on a 09 model. Had to manufacture additional bracket, because the ignition coil was in the way.
Instalaltion is pretty easy - there are two tubes that are mounted in front of the radiators, and brackets that are tightened on the frame under the tank. Right and left guards are different!
Thanks I actually just finished putting them on.
The right side one actually came with a longer bolt to go through the ignition coil right side hole. The left side had a rectangular brack that went around the frame under the gas tank.
Pretty easy once I broke down and started looking at it.
