M Mikeyx New member Sep 20, 2018 #1 I need a new can for my EC300 Racing, m.y. 2009. Is there an alternative to the OEM silencer BE870002510 ?
(F5) Gold Level Site Supporter Sep 20, 2018 #2 Why? Has the std inner fallen apart? You can rebuild them with some perforated tube and someone with a welder.
M Mikeyx New member Sep 20, 2018 #3 Rivets won't last long and hence the rivet holes have stripped through the shell.
(F5) Gold Level Site Supporter Sep 20, 2018 #5 You can get some larger but larger head rivets that hold better, you know the ones? They are like 12mm heads.
Davehuge Member Sep 24, 2018 #6 Hi Mikeyx If you decide to replace your silencer, I can strongly recommend the DEP silencer, good quality and great price... See this post... http://www.gasgasrider.org/forum/showthread.php?t=23568
M Mikeyx New member Sep 26, 2018 #7 Thanks Dave - this is just what I've been looking for. The flange of the incoming pipe, which is riveted to the shell, has no longer holes but U-shaped openings instead...
M Mikeyx New member Oct 13, 2018 #8 Found the root cause to my problems. Retainers BIC050526004 and BE25626004 were toast. I found an OEM silencer for an affordable price from gasgas-outlet.de. They deliver to Europe only.
