Cycra hand guard mounting options
I'm dead set on cycra pro bend hand guards, unless something better is out there but as seeing how i can't use the triple clamp mounts IMO the sturdiest ones because of the inset hex key bolts. I wanted to hear your opinion/experiences with mounting these guards. should I just go with the conventional bar clamps? I have 1/8th bars. I know there are a few other options for mounting besides those two, but I've never used them to know if they work or not
your knowledge is greatly appreciated
i can't use mounts like the ones in the picture
295227
because my bike doesnt have 10-12mm bolts it has counter bored hey key bolts
these are the mounts that I would prefer to use
I use the Cycra CRM mounts. Works good, and provides easy routing of cables etc.
http://store.cycraracing.com/ceremo.html
I'm using those as well. Makes for a tight fit on the fork adjustment clickers, you really can't make any adjustment with them on. I end up removing the bars to make any adjustment. Also had to do a bunch of trimming on the bar pad, even with that the velcro bit barely reaches around the pad/bar.
I don't see any better option than these though. It didn't seem like the triple clamp mounts would work to me either.
I am actually able to adjust the clickers on my KYBs, however I use a Scott sub mouted damper, hence the bar is raised compared to stock position.
Sent from my GT-I9505 using Tapatalk
I used pro bends with bike bonz mounts, they work great and I like how they integrate and act as the top bar clamp too. They make the hand guard un twistable as I had problems with others moving in hard get offs. If you want a set I have a pair since I moved to the twisted engineering bars, I can't use them with there system
Cycra Center Reach
Get the CRM - Center Reach Mount hand guards. http://store.cycraracing.com/ceremo.html
They work great.
1+ on that, the center reach clamps have four bolts per clamp and because they are toward the center of the bar you get a full circumference grip to the bar.
And for the bar inserts - HIGHLY recommend these inserts.
http://www.spudbilt.com/Products/BarInserts/tabid/256/Default.aspx
You thread your bar end and then thread in these inserts with thread locker. These inserts combined with the center reach mounts mean you will have a very solid hand guard system.
I had the Cycra CRM mounts but they would turn when I crashed at times. I made some aluminum mounts copied from the BRP style top mounts. I also removed the crossbar from myRenthal bars and added anti-vibe inserts in the ends of the bars. This combination is pretty much bullet proof no twisting and much easier on the hands and wrists.
I'm running the BRP unit. They are very nice and have a place to mount your computer.
I went ahead and got the cycra CRM guards, ill see how well the stock center mounts hold up, if they don't ill be getting the brp mounts or that style of mount
